Добавлено: Ср Июл 08, 2026 4:04 pm Заголовок сообщения: What are the bases in dating |
Article about what are the bases in dating:
В» GoDates
Have you ever heard someone (usually guys) bragging that they ",got all the way to the home base last night",? What are the bases in dating? What Are the Bases In Dating?
>>> GO TO SITE <<<
Have you ever heard someone (usually guys) talk about trying to “get past first base” or bragging that they “got all the way to the home base last night”? This might sound confusing—surely they aren’t talking about baseball? Unless they are sports players talking about a game, they are probably using dating slang. If you are trying to find out “what are the bases in dating?” we will explore everything you need to know here! What has baseball to do with dating? Baseball itself does not have anything specifically to do with dating. However, the baseball terms as euphemisms to describe sexual activity have been used for almost as long as the sport has been around. The conservative culture of 1940s America meant that people were often more comfortable using sports terms than biological ones. Even though we can be more open about these things nowadays, this slang has stayed popular. The metaphor of bases in dating has become popular after the Second World War. It has been used in many movies, TV shows, and pop songs. You may know Meat Loaf’s single “Paradise by the Dashboard Lights,” where you can hear it being mentioned. In baseball, the “hitter” (or the player who uses the bat to hit the ball) must run around the field to reach four different bases. The game’s goal is for the hitter to reach as many of the four bases as possible before being struck out. If the hitter reaches the fourth base, this is known as a “home run,” which is the ultimate goal. For many young people, especially during the early stages of dating, sexual activity can seem like a challenge in the same way that sports such as baseball are. The use of different “bases” to help describe sexual activity has become a tradition that has continued worldwide. So what are the bases in dating? First base of dating. The “first base,” like in the sport, is the first notable milestone reached. When it comes to dating, the first base is reached when a couple kisses each other. However, this does not mean any kind of kissing. A kiss on the cheek, or even a quick peck on the lips, is not usually considered first base. Generally speaking, the first base refers to a more sexual type of kiss that lasts longer, the partners use tongues, or touch and stroking the hair or the neck. This is often known as “French kissing.” Sometimes, people may skip this base. In casual relationships such as “friends with benefits” situations, people might reach every other base except for this one! However, in the context of dating and romantic relationships, this is usually the first milestone. A great first kiss can signal how much of a spark there is between two people. Of course, any of the other bases can also include kissing, but kissing on its own is known as “first base.” Second base of dating. The second base is where things start to heat up and become even more physical. It may be common to see people kissing or even French kissing in public, but it is unusual to see people taking things to this stage. The second base of dating involves touching other body areas rather than the face, head, or neck, yet staying above the waist (however, squeezing someone’s butt is often included in this). We’re not talking about a grab of the arm or a quick stroke of the shoulder, but more intense and prolonged touching. Rubbing and grasping the chest, including breasts and nipples, is usually what the term “second base” refers to. By this point, couples may want to move to the next base as quickly as possible. However, staying in the second base for a while can really build excitement and be surprisingly intimate. Third base of dating. When the second base goes on for long enough, it can be difficult for couples to resist going further. The third base is quite a broad category that encompasses various different acts, all of them “below the belt.” If there are hands in pants, you’re at the third base. The third base is anything that involves the genitals but falls short of full penetration. This could mean either or both partners touching or manually stimulating the other’s genitals. It can also mean oral sex—either performed by one or both members of the couple, either in turns or sometimes at the same time. Any act within the first three bases can be known as foreplay, although these acts can also be enjoyed as their own ends! You may think that only full penetration carries risks of sexually transmitted infections. However, this is not the case.
what is second base in dating
what is 1st base in dating
what are the four bases of dating
in dating what is first base |
