ok google знакомства бесплатно
СообщениеДобавлено: Чт Июл 23, 2026 9:54 pm    Заголовок сообщения: ok google знакомства бесплатно Ответить с цитатой
Статья о ok google знакомства бесплатно:
Even when you don’t want it to. How To Turn OK Google On and Off on Your Android Device. Google Assistant is always there for you, and always listening.
Even when you don’t want it to. It can be very convenient to say “OK Google” and have a digital assistant answer you right away. But what if you want to turn that assistant off? Whether it’s due to privacy concerns or any other reason, it doesn’t seem very straightforward to turn the OK Google feature on or off on your phone. In fact it doesn’t seem easy to adjust many of the Google Assistant settings. It’s for this reason that we’re going to offer this guide on how to turn OK Google on or off whenever you like, and also other useful settings you may want to adjust. How To Turn OK Google Off. Unfortunately, turning the OK Google feature off on your Android isn’t very easy to do. For starters, it’s difficult to find the setting. Whether that difficulty is built into the app intentionally is debatable, but at least it’s possible to disable it. Open the Google Assistant app. Tap the Explore icon at the lower right corner of the display. Tap your profile icon at the upper right corner of the display and tap Settings . In the Settings window, tap Assistant in the menu. Scroll down to the bottom of the Assistant settings menu and tap Phone under the Assistant devices section. On the Assistant settings screen, you’ll see a toggle switch you can disable next to Hey Google under Voice Match . This setting is misleading, because it also enables and disables Assistant’s response to the statement “OK Google” as well as “Hey Google”. However, disabling this toggle switch will in fact turn OK Google off. If you ever want to turn OK Google back on, just repeat the process above, but enable the toggle switch to the right of Hey Google . Configure Other Important Google Assistant Settings. When you start digging through Google Assistant settings, you’ll see that there are a lot of useful settings buried there. The following are some of the most important Google Assistant settings you should know to make better use of Google Assistant. Add Your Places. If you’d like to be able to tell Google Assistant to “navigate home” rather than having to list your entire address, you can do that by adding “home” to your list of Places. To do this, access Google Assistant settings just like you did in the steps above, but this time select the You menu at the top of the screen. Select Your places from the menu. On the Your places screen, select Add a new place . This will open a new screen where you can search for the location by address or name. Type a name for the place that you’ll remember and is easy to say. When you’re done, just select OK .
