Михаель
Добавлено: Сб Май 23, 2026 12:52 pm Заголовок сообщения: Quick flirt customer service |
Hello, Guest!
Article about quick flirt customer service:
Create quick replies. Omnichannel for Customer Service offers a suite of capabilities that extend the power of Dynamics 365 Customer Service Enterprise to enable organizations to instantly connect and engage with their customers across digital messaging channels. An additional license is required to access Omnichannel for Customer Service.
>>> GO TO SITE <<<
For more information, see the Dynamics 365 Customer Service pricing overview and Dynamics 365 Customer Service pricing plan pages. Quick replies are predefined messages that can be created for agents to quickly respond to common questions from customers. For information about the agent's quick reply experience, see Send quick replies. To create quick replies. In Dynamics 365, go to one of the apps, and perform the following steps. Customer Service admin center Omnichannel admin center In the site map, in Agent experience , select Productivity . In the site map, in Advanced settings , select Agent experience . Select Manage for Quick replies . To create a quick reply, select New , or to edit an existing quick reply, select the name of the quick reply. Provide or change the following information: Title: Enter the title of the message. Locale: Specify the language of the message. Omnichannel for Customer Service does not localize quick replies. To provide quick replies in multiple languages, create a separate quick reply for each language and select its corresponding locale. Message: Enter the text of the message. The Message field supports the following slugs. Select Save . Create or edit tags for common categories of quick replies. Quick replies can be classified and tagged into categories. The categorization capability can also be leveraged to group quick replies into logical chunks that represent key conversational states for agents. These logical chunks help agents select appropriate messages that correspond to customer issues. In the site map of Omnichannel admin center, select Agent experience under Advanced settings , and then select Manage for Quick replies . In the Omnichannel Administration app, go to Agent Experience > Quick replies . Select two or more quick replies for which you want to create a tag, and then select Edit Tags . The Edit Tags dialog box appears. In the Add new tag field, start typing the tag you want to create. If it already exists, it will appear in a list below the field. If it doesn’t appear, select the plus + sign to add it. After you're done, select Close . Associate quick replies with a workstream. For organizations with diverse lines of businesses, agents will send a variety of messages, depending on their area of expertise. Administrators can determine which quick replies are necessary for different groups of agents to use. Administrators can associate quick replies with workstreams to show agents only those quick replies that apply to them. If no workstream is associated, the quick reply is available for all agents. In the site map of Omnichannel admin center, select Agent experience under Advanced settings , and then select Manage for Quick replies . In the Omnichannel Administration app, go to Agent Experience > Quick replies . Select a quick reply from the list. In the Workstreams section, select Add Existing Work Stream . Select the workstream from the list of records, and then click Add . The workstream appears in the list. Select Save . If you select the workstream in the list, you can view the workstream record, and see the quick replies associated with the workstream. Availability of quick replies and language settings. The quick replies that the agents will see is determined by the following parameters: The language mapped to the channel instance The language configured in the agent's personal settings The workstream the quick reply is mapped to. For example, when you set up a live chat widget or Facebook page, the quick replies will be available in the language that is configured for the chat widget or Facebook page. Then, when you associate the chat widget with a queue containing agents, the agent-specific language setting, if configured, will determine the language in which the quick replies will be available to the agents. The agents will see the quick replies mapped to the workstream that is associated with the channel with other quick replies.
quick flirt customer service |
