Михаель
Добавлено: Пн Май 25, 2026 1:04 am Заголовок сообщения: date corner dating site |
Hello, visitor!
Article about date corner dating site:
Learn how to activate Facebook dating, get a dating profile, and use the FB dating app. How to Activate and Use Facebook Dating. You need a Facebook account and must be at least 18 to get started.
>> ENTER THE SITE <<
In This Article. Jump to a Section. What to Know. Tap the Facebook app's Menu in the lower-right corner, then tap Dating . Set up your profile. Adjust your settings by tapping the gear icon > General . Set criteria for matches, connect your Instagram, and more. This article explains how to activate and use the Facebook Dating app for iOS and Android so that you can start making matches. How to Activate Facebook Dating. You need a current Facebook account and must be 18 or older to use the Dating app. You don't have to create a separate dating profile on Facebook, though, it uses the information on your current profile to recommend potential matches based on shared interests. Follow these steps to get started using Facebook Dating: Open the Facebook app and tap Menu (three lines) in the upper or lower-right corner. (Menu location varies by mobile platform.) Tap Dating . Tap Get Started . Follow the prompts to set up your dating profile. After you share your location and choose a photo, your dating profile will be generated using information from your Facebook account. Customize your Facebook Dating profile by adding more information, photos, and even posts from Instagram. Tap Done when you're satisfied. What to Know About Using Facebook Dating. Your profile will also be recommended to others who have Facebook Dating activated. Facebook's dating feature is similar to Bumble and Tinder in that you can't message other users until you both express interest in each other. Since the dating feature draws information from your regular Facebook profile, you should fill that out as much as possible. There is no separate Facebook Dating app or Facebook Dating site, the feature is integrated into the Facebook mobile app. Pictures and other content you share via Facebook Dating don't appear on your regular Facebook profile. Conversations on Facebook Dating are also kept separate from your Facebook Messenger conversations. If you become Facebook friends with someone after matching with them on Facebook Dating, you can still see their dating profile. The app will begin recommending profiles one at a time. You can go to the Dating section on the Facebook app at any time to see your recommendations. Here are five actions you can take when using Facebook Dating: Tap the heart on a user's profile to let them know you like them, or tap the X to pass. If they like you back, you can start a conversation. If someone else likes your profile, you'll receive a notification. Tap the heart on their profile to like them back so that you can send a direct message. You can view your matches and conversations by tapping Matches at the top of the app. Scroll to the bottom of your profile and tap Answer a Question to answer random questions that will help Facebook improve your match suggestions. You can also add photos and share Instagram posts at the bottom of your profile page. How to Adjust the Facebook Dating Settings. Changing a few settings will change how the Facebook Dating app works for you. Tap the gear on the screen where Facebook suggests profiles to access the settings. Under the Ideal Match tab, set your preferred criteria for potential matches. Under the General tab, you can control what shows up on your profile. To connect your Instagram account, tap More (three dots) next to Instagram . Facebook Dating Secret Crushes. You can match with your Facebook friends and Instagram followers through the secret crush feature. To do so, scroll to the bottom of the screen where Facebook suggests profiles and select Secret Crush . You can then select friends on Facebook and Instagram. If they are set up to use Facebook Dating, they'll get a notification that someone has a crush on them, but they won't know who. If they also add you to their secret crushes, then you will be matched. The app won't suggest any of your current Facebook friends and your dating profile won't be visible to any friends who use the feature. However, friends can add each other to their secret crushes list, so you could match with a friend if they have a crush on you. How to Delete a Facebook Dating Profile. It's possible to delete your Facebook Dating profile without deleting your regular Facebook profile, but deleting your account will remove you from Facebook Dating. |
